1997 850, no crank, trans arrow, econ light flashing
Re: 1997 850, no crank, trans arrow, econ light flashing
I'll be taking some time tomorrow to check the wiring out, I located a thread with a link to the wiring layout and was going to give that a peek as well. in the same post, "1996 850 turbo - dash indicator lights stuck on", it mentioned they had warning lights like mine staying on after the key was removed just as I do. They traced it all over the ignition switch and then came down to the fuse box. does the fuse box just slide out to reveal its connections?
DrJammer
- Year and Model: 2000 V70XC - 195k
Based on my volvo driving, not mechanical, experience, that sounds like an alternator heading south. find out, since I don't think it throws codes and you may end up losing power while driving.
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
2008 S60 - leased
- Has thanked: 1497 times
- Been thanked: 3809 times
There are tons of grounds on Volvos and they are all starting to go bad on these cars as they approach 20 years in age.
