1995 volvo 850 windshield wiper nut
galerie
Year and Model: 1995 850 GLT
Post by galerie »
The nut that holds the drivers side windhsield wiper arm comes loose when I use the wipers frequently. Can I put some loctitie on that nut so it won't come loose so quickly. Any suggestions would be appreciated.
Has thanked: 1497 times
Been thanked: 3810 times
Is the nut coming loose or the wiper arm coming loose? You can put a small piece of aluminum foil over the spoke the wiper arm mounts into to increase the friction, but still provide a break away point for the wiper arm.
galerie
Post by galerie »
I think its the nut, since that is what I have to tighten. I will try a little piece of foil to see if that helps...thank you so much
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
I have had the same problem on our 94 850. I used Locktite to secure nut.
