2003 V70 Accessary Belt Tensioner Bearing
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 78 times
Can anyone verify that the correct accessary belt tensioner bearing is a NTN 6203 (17x40x12)? Mine is starting to howl when hot but I need to buy the bearing before tearing it apart as I only have the one car at the moment. I don't really want to ride my bicycle the 10 miles to the bearing supplier. Thanks.
- Year and Model: Lots
- Been thanked: 128 times
chrism
Good point. The Napa website says my local store has two different pulley/bearing assemblies for about $13 and $25 respectively. I may just go that route along with a new Conti belt. The existing tensioner has 200K miles on it while the belt has about 35K at 3 years old. I can't decide if it's the tensioner or the belt that's squealing. The tensioner sounds pretty rough through the stethoscope but it really sounds like a belt squeal, plus it increases when I load up the A/C compressor and increase the alternator demand. The belt is nice and snug so I don't think the tensioner spring is weak. The odd thing is that spraying water on the belt while it's running has no effect on the noise as I would have expected. Maybe serp belts don't respond to the water test the same way V belts do.
BTW - would you happen to know off the top of your head what size star bit fits the tensioner? I want to make a tool with a long handle for it. Thanks.
jimmy57
- Been thanked: 320 times
203FF is the one I have been buying at AZ and O'Reilly's. It is the 17x40x12 sealed alternator bearing.
It may be an interchange to another number also.
203ff.docx- (76.05 KiB) Downloaded 130 times
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 116 times
Everyone I asked said 55T, but it was 60T for OE/INA.chrism wrote: BTW - would you happen to know off the top of your head what size star bit fits the tensioner? I want to make a tool with a long handle for it. Thanks.
I purchased Lisle from Amazon for $6. It takes 3/4". No need for a long handle.
jimmy57
The torx is cantankerous to get the tool into so I always use a boxed wrench on the bolt for the pulley.
I have pressed bearings into the plastic wheels when the surface is OK. Oven heating would be a good idea as it reduces the chance of cracking the plastic wheel.
- 200 Views
Last post by RedBrickCollector
- 2149 Views
