1999 s70 volvo power windows and wipers do not work when car
My 1999 s70 volvo wipers and power windows do not work when engine is running. However when key is only turned to the on position they do work. What is going on?
- Year and Model: Lots
- Been thanked: 128 times
That's certainly an odd one. Disconnect the battery and go and press your brake pedal to discharge any remaining charge in the electrical system. After this reconnect the battery and see if things improve. Have your radio code handy as it will bebasking for the code.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- Has thanked: 1498 times
- Been thanked: 3810 times
Ignition switch, electrical part?
Or
One of the load relays is flaky
Or
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
I agree - Start with simple ignition switch check.
Jiggle the key when things are inop as a preliminary test.
You can certainly get a lot more technical, but start there.
- 514 Views
Last post by BEJinFbk
- 797 Views
Last post by precopster
