2002 S80 2.9LSmall Jerk In Engine When In Idle
divinedavis
Year and Model: S80 2002
Post by divinedavis »
I've recently changed the PCV Valve Oil Trap (FCPEuro.com) which stopped the whine. It stopped the RPM fluctuations also. When I'm in park or when I'm in drive and I have the car idling it seems to have a small jerk once every two seconds. I have 138,000 miles on the car. The lights would dim a little every time the car would find itself jerking.
Just had the oil changed (which I regret i didn't do myself).
I changed the spark plugs.
The fuel injectors are clean with no gunk.
I cleaned the throttle body.
The MAF looks pretty damn clean too.
Oly_850
Year and Model: 2000 S80 T6
Post by Oly_850 »
Are you getting a Check Engine Light and are there any codes? At first blush this sounds like an intermittent misfire P0300.
'12 Ford Focus SE - Black Pearl
Owned:
'00 Volvo S80 T6 - Maroon
'98 Volvo V70 - Red
'90 Volvo 740 GLE - (sold, too far gone)
'96 Volvo 850 GLT - (totaled) :\
Want - A6 Quattro, XC90, C303
divinedavis
No more check engine light. I just get a small jerk when I idle & when I turn on the AC.
rmmagow
Year and Model: V70 1998
Post by rmmagow »
Are you sure it isn't just the A/C kicking in? Leave the A/C off for a while and see if jerking stops.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
divinedavis
It still happens, but not as much.
Oly_850
Post by Oly_850 »
Is it regular and does it vary with RPM? Do you have to have the A/C on to make it happen, and do RPMs fluctuate?
Worse when the car is cold?
Owned:
'98 Volvo V70 - Red
divinedavis
It's regular. The RPM does not fluctuate anymore. It stays at about 700-1200. When the A/C is on it still doesnt fluctuate. Just a small jerk, feels like something stops for a millisecond.
divinedavis
The car has just started these problems so i dont know if it's worse in the cold.
Oly_850
Post by Oly_850 »
I think your got a coil over pack that is:
1) not grounded well ( booted down tight, two harness connections clean & tight)
2) arcing to the head through a torn boot
3) just weak, has yellow dim spark
OR
Your cam position sensor on the rear camshaft on the drivers side is not giving you a consistent ignition trigger.
Either way, any of these conditions should light up a MIL lamp.
Have you had the codes read lately?
Owned:
'98 Volvo V70 - Red
divinedavis
Where do I have to go or what do I have to get to get codes read? & THANKS!
