2000 S70 Transmission project Topic is solved
wheelsup
Year and Model:
Has thanked: 15 times
Been thanked: 20 times
Re: 2000 S70 Transmission project
Post by wheelsup »
Ozark Lee wrote:My guess is that Matt would rapidly have a cease and desist slapped on him if I tried to upload it. ATSG tends to defend their copyrights vigorously. The link to the .ru site came up with a Google search for "Aisin AW 50-42le repair" and it was on the first page. They don't exactly have gigabit speed off of the server but it was only a few minutes to download it.
Thanks Lee you are probably right! I'll use a hotel computer to download I don't trust those foreign ip's!!
1995 850 GLT Wagon w/ 200,000 miles
wheelsup
Year and Model:
Post by wheelsup »
precopster wrote:
Last time I looked at the Hastings cattalogue they had 2.4 rings but that was over 2 years ago.
I'll check there thank you. I did find one set but they were close to $500, seemed like a large amount for just rings.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
What plate in the pump is cracked?
Transtar is a good source for hard parts. They will have used and new available.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
This is the plate inside the pump assembly that was cracked. Its the last one of the smaller clutch package. As far as I can see this plate and also all of the plates in the clutch that burned up is the only hard parts I will need.
BMW 540i 2002
S70 Base 2000
jimmy57
Post by jimmy57 »
That is the C2 pressure plate. That clutch is carried by the pump but is not the pump.
Make sure the piston behind it is OK and the housing isn't damaged in some way to make the piston hang.
Usually there is a cause for a part like that to crack.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The banging that sluggish solenoids creates can be a cause of shock damage in these transmissions.
However be very thorough in the way you rebuild both the valve body and the other areas. The largest gasket on the valve body plate is usually baked on and requires the use of a dishwasher or immersion in boiling water to remove.
Ctp Powertrain sell a Transtar kit packaged with all gaskets and a nice cork VB gasket.
kallekula
Post by kallekula »
jimmy57 wrote:That is the C2 pressure plate. That clutch is carried by the pump but is not the pump.
Oh ok thanks for the tip. I will look closely at all the parts I will take apart. This is my first auto transmission job I've done so I really appreciate all the help I can get :)
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
precopster wrote:The banging that sluggish solenoids creates can be a cause of shock damage in these transmissions.
Yes I had the banging when the tranny was hot for quite a while. Maybe it was wat caused the damage to the steel plate I have no idea. Gonna do the solenoids at the same time.
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Bought the overhaul kit today and some hard parts.
BMW 540i 2002
S70 Base 2000
Has thanked: 1502 times
Been thanked: 3817 times
This thread makes me feel like a velvet Elvis painter in a room full of Picassos, Dalis, and Sergels.
Carry on!
:D :D :D
