96 850 turbo oil line leaks, need advice
neworleans
Year and Model: 2007 S60R
Post by neworleans »
Hello all,
Noticed a leak today on my 850 Turbo, took some pics and attached them, can you all please tell me which line this is and is it easy to replace? Thanks for any input.
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I had a leak in that line too. I replaced both lines with new OEM parts and wrote it up here:
https://www.matthewsvolvosite.com/forums ... 4&p=282557
Others have reported good success and great savings by building up their own lines with hose clamps or getting the crimps redone.
Been thanked: 471 times
Post by cn90 »
Rebuilding TRANS Cooler Lines DIY for $10, Engine OIL Cooler line similar:
https://www.matthewsvolvosite.com/forums ... p?p=328187
For Oil Cooler Lines DIY, there are certain tricks/tips, I posted them below (note you need new rectagular seal, new Green O-rings at tstat area, and new O-rings at the cooler area.
Don't forget that the metal clips only fit one way at the cooler! Also use a screw-type clamp to secure the metal clip, otherwise it can become disconnected: all oil will be lost!!!
https://www.matthewsvolvosite.com/forums ... 7&p=311050
