98 Volvo S70 GLT Metal clips for oil lines at radiator
MikeS70GLT
Year and Model: 1998 S70 GLT
Post by MikeS70GLT »
I am having my radiator replaced and the mechanic suggested I get spare clips for the oil lines that connect to the radiator in case they break (one at each corner). Are these metal clips easy to find in auto stores? And if not, where can i find them online. This site has been great for helping me with these miniscule issues so I thought I'd try here before going to the dealership.
Has thanked: 1502 times
Been thanked: 3817 times
You can just use hose clips or zip ties on these, I recall from other posts
On edit...to clarify, you use both the Volvo supplied clips and secure them with a hose/jubilee clamp or a zip tie. Red zip tie of left, green on right.
Atis
Year and Model: S70 GLT 1998
Been thanked: 4 times
Post by Atis »
If you buy Nissens radiator, there will be new ones supplied with the radiator.
MikeS70GLT
thanks for the info. i purchased a radiator through genesisautoparts.com and it didn't come with the clips but from what i've read screw hose clamps are a solid substitute. i'll try the local auto stores just in case.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I would re-use the clips and then put a zip tie over it like abscate has noted. My friend had a clip come off while he was driving so I have all 4 of my lines zip tied over the clips.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
MikeS70GLT
ah ok i got it. the only reason i ask about replacement or substitute clips is just in case any of them happen to break, this issue doesn't seem to be too common but better to be safe than sorry.
Been thanked: 470 times
Post by cn90 »
- Re-use the metal clip, no need to replace it but here are the tricks:
1. THICK side of the metal clip faces the radiator, THIN side faces the engine!
2. Place a screw-type clamp over the metal clamp and snug it down. For photo, see the pic posted by xHeart:
https://www.matthewsvolvosite.com/forums ... p?p=328212
Photos are below...
MikeS70GLT
oh wow great tips and photos! thanks for all of the great help
Post by cn90 »
The THICK and THIN side of the metal clip: I learned it the hard way. Back in 2008, the indy replaced the rear main seal for me as I don't have a lift.
He placed the metal clip backward: THIN side toward the radiator!
A few months alter, during a winter storm, icy road, I lost most of ATF on the highway, but luckily crawled to local Target store to buy some Dexron-III.
Next morning, poured ATF in, as soon as engine started, it poured out the upper cooler connection at the radiator.
Went to Volvo dealer to buy the metal clip, thinking it was the culprit. A master mechanic happened to be at the parts counter and told me I don't need new clip, all I need is the PROPER orientation: THICK side ---> radiator. And a place a clamp over it.
He said at the dealership, they see this all the time, private indy shop does the ATF flush but put the clip backward ---> ATF leaking. So at dealership, they routine place clamp over the clip as a standard procedure.
Another note: when you remove the clip using snap-ring pliers, you can spread it too much that during installation, it does not "bite" properly, thus the screw-type clamp is the ticket!
Has thanked: 292 times
Been thanked: 765 times
A zip tie on top of the old clamp works great, is super cheap and easy, and I have never heard of a single one failing.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
