'98 V70 GLT Ticking
MoparWade
Year and Model: 98' V70
'98 V70 GLT Ticking
Post by MoparWade »
Was out driving this evening. Decided I hadn't really opened it up in a while. Mash the pedal and as soon as the boost built up it started missing. Pulled into my driveway a minute later and noticed the I now have a ticking. Not quite a knock like a spun bearing but what sounds like some one tapping a screwdriver against metal. It matches my RPM and doesn't seem to flutter. Dead lifter? Ideas?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Is it still missing? Do you have a CEL? You might have a burnt valve.
MoparWade
Post by MoparWade »
No CEL. I actually suspect that the miss was caused by the boost going above what I am tuned for but I still feel like there must be some connection.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Does the noise reduce when adding oil?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
MoparWade
Post by MoparWade »
Haven't added any oil yet. If it is a lifter it is just one.
MoparWade
Post by MoparWade »
Added oil and no change. It did seem to be a bit louder with cold start.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Bent connecting rod, piston skirt rattle.
If it is too fast for lifter rattle then this is a real possibility. Lifter rattle is once every two crank revolutions.
Did it run REALLY good just prior to the misfiring like symptoms?
Bent rod caused piston skirt rattle will sound out louder behind and below exhaust manifold.
Has thanked: 1504 times
Been thanked: 3817 times
Ugh. Are you at stock boost or have you been playing
