I recently purchased the LED rear license plate lights from IPD since mine were out. I replaced the lights and nothing worked. I even bought regular bulbs and replaced the LED bulbs but the lights still did not work.
My question: is there a fuse or common fault that causes this? Age causing these sockets to no longer work?
Dustin
97 850 rear license plate lights
- BlackThunder
- Year and Model: 1997 850
- Has thanked: 6 times
- Been thanked: 3 times
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
2013 Volvo C30 T5
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
It may be possible that you have a broken wire in your rear hatch harness, if you have a wagon.
- Year and Model: Many Volvos
- Been thanked: 75 times
My son had the same problem with his sedan and it turned out to be that the wires that track along the left hand side trunk hinge were chopped, likely from someone slamming the trunk with something in the way. The wagons suffer a similar problem but it is from the wires flexing at the hinge point for the tailgate.
Both are fairly easy repairs once you find the problem. I used solder and heat shrink to splice the wires back together but many have used butt splices.
- BlackThunder
Ok, I'll look for that. Thank you!
Dustin
Dustin
Dustin
2013 Volvo C30 T5
2013 Volvo C30 T5
- Has thanked: 1502 times
- Been thanked: 3817 times
do a quick search for the rear wiper intermittent problem - there are some nice pictures of the wiring harness on wagons there...
