1994 855T decreasing MPG
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
I am going to assume the front O2 sensor is at fault, since I can't think of anything else that would make the MPG's decrease over about a year's time. It's down to about 21.5 on the highway. My former mechanic said the rear one was going, but that it had no effect on the MPG's. This will be my first O2 sensor job on an 850 - do I have to use an Volvo sensor, or is there a reliable substitute?
But please correct me if I'm missing something.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
There are a few things that can effect your gas mileage. When was the last time the car had an ignition tune up?
Get a Bosch sensor.
azureblue
Post by azureblue »
Thanks -I'll pull the distro cap - it and the rotor are about 3 years old, and check them out. Wires are about 4 years old and they are Volvo wires. Changed the plugs about 6 months ago, but that's about it. (to NGK plats for turbo gapped down to.025 - the car runs great). I have no idea how old the O2 sensors are - the PO replaced them so they have to be at least 5 years old. Bosch it is, then...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Clean them with MAP sensor cleaner and put a bit of anti-seize on the threads. 5yrs is not old especially for Bosch sensors
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
azureblue
Post by azureblue »
I'm not sure if they are 5 years, but the PO replaced the engine, and had everything updated about 12 years ago. Cleaning them doesn't look like much work, so I will try that. I need to do a MAP clean in another car I own, anyway...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I had the front O2 sensor failed on my car. In city driving as well as in stop and go traffic, the mpg was very low, around 15mpg. On the highway however I was still getting a 30mpg. I believe a failed sensor affects the mpg mostly when the car is accelerating.
azureblue
Post by azureblue »
That's good to know - my in town MPG is pretty good. I used to average about 24 MPG but that has dropped to 21.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Has thanked: 1505 times
Been thanked: 3818 times
Recent London poster solved his surging problem with a new fuel pump. A side symptom was low mpg like your report. Check fuel pressure at rail.
osman
Year and Model: 2002 c70 hardtop
Post by osman »
Once had my turbo wagon go all they way down to 11 mpg all kinds of black smoke, I replaced everything starting with the front O2 sensor, FPR, ECT, Spark plugs, wires, cap and rotor, you name it. It finally ended up being the ECU, got one from the junkyard for $20. Car ran like normal.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
mecheng
Post by mecheng »
I find if the o2 sensor is getting lazy "slow response" codes sometimes all they need is cleaning, mpg is usually down slightly. If the mpg is very low the O2 sensor is shot and needs replacing
