1994 Volvo 850 Rear Negative Camber
Baptiste1106
Year and Model: 850 1994
Post by Baptiste1106 »
I noticed my rear tires have negative camber and a lil puzzled on why. I am a mobile mechanic so i do travel with all my tools, but i upgraded my rear coils to IPD overloads. What do alignment shops adjust on volvo 850's ?
volvo trunk.jpg (127.12 KiB) Viewed 1978 times
Has thanked: 292 times
Been thanked: 765 times
On the rear, only the toe is adjustable.
From the factory manual, regarding the rear camber: "If camber angle is not to specification, check for trailing arm damage."
WheelAlignmentSpecificationsProcedures.pdf
From the factory service manual.
(70.47 KiB) Downloaded 355 times
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
blandis
Year and Model: 99 S70 T5
Been thanked: 3 times
Post by blandis »
I am trying to solve the same issue on my 99 T5. Mine is only the passenger side and it is .1 out so very minor.
The do not make a shim kit for the rear of these cars that I can find. I replaced delta links, did not solve my issue.
Next step for me is to replace both rear end anchorage mounts. Have them both, just have not made time to tear into it.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
blandis
Post by blandis »
99 S70 T5
Replaced delta links and did not impact rear camber at all.
Replaced Trailing arm bushing on both side today. Passangers side very simple, drivers take a bit more time. Camber much worse on passanger side now. Drivers side off now, was not prior to parts change.
What am I missing? Attached is my after alignment figures. I am stumped. Any advice. May start a separate thread to discuss.
Rear Camber s70.jpg (117.69 KiB) Viewed 1950 times
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
Baptiste1106
@ blandis... I was just about to ask MVS what bushings in the rear contribute to proper alignment ? Need an alignment dont feel like wasting time at the alignment shop. It seems as if these volvos are a special case
Baptiste1106
My boy @ Volvo says, that Volvo service center just updated their alignment machines and to get it done by them. He suggested changing the 4 bushings in the rear 2 on each side. Hope this helps MVS
blandis
Post by blandis »
Baptiste
I have replace all 4 of those bushings. Delta links (top picture) first, virtually no change to the alignment. Then the other two and seems to be worse now on the passangers side especially.
Is there an update to the hunter alignment machines? Or did Volvo update alignment procedures?
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
