ECM-5000 A/C Pressure sensor Signal too low
Suppose you have to replace the sensor. Would you have to empty the refrigerant?
Or you just unscrew the sensor and put another one in place? Totally dry work?
is A/C Pressure sensor replacement a "DRY" work?
S60 2002 180K miles looks and runs like new (except when sulking)
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
Recover freon, replace sensor, evacuate system and then recharge.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
CountryBum-kin
- Year and Model: S60 2002
Should be able to replace it without opening the system,but its been a while .
- Has thanked: 1505 times
- Been thanked: 3817 times
On my 1999 there are presto (tire type) valves under each sensor allowing replacement without losing the AC charge.
I've never worked on my 2005 P2 AC but Alldata says replacement requires charge evacuation/replacement
Mine is a 2002
Vida shows me 3 sensors;
one on the receiver dryer (pressure sensor?)
one on / attached/ close to the refrigerant pipes inside the cabin (temp sensor?)
and one somewhere else (could be the same as the second one)
I try to put my hand on the first one (on the dryer) but the refrigerant hose seems to get lost underneath the cooling fan and the radiator. I can't see it. Do I have to remove the fan / coolant hoses to find out it is not there??
Mine is a 2002
- regent
You can see the pressure sensor on the dryer with a tiny inspection mirror and a flashlight. To replaece it, you will still need to depressurize the system in a legal fasion.
At 15 years of service, I would replace the dryer as well - since I am at it - and then vaccum and refill afresh.
Cheers!
Cheers!
2015 BMW 335i
2015 BMW 335i
Thank you very much for even more discouraging words "see it with a tiny inspection mirror and a flashlight"
(with a Ralph Kramden accent)
Gee how am I going to put my hands on it and work there, I who have difficulty dialing a cell phone.
If it starts giving problem I might have to see a AC specialist $$$.
- regent
It is doable, however, according to VIDA you take the rad out of the way. I believe there was a workaround procedure of some sort if you want to try to search here on the forums.
As for the cellphone dialing-related challenge, there are all kinds of voice command apps that can do that for us
2015 BMW 335i
2015 BMW 335i
- 8577 Views
Last post by - Pete -
- 16 Replies
- 3002 Views
Last post by JohnnyRingo
