1997 850 NA - Cannot clear P0172
dejongmc
Year and Model: 2004 Volvo S80
Post by dejongmc »
I have this code for a while now and it will not go away. Here a list of things I did so far:
- Replaced all vacuum lines incl. canister under intake manifold
- Replaced spark plugs and wires (were due anyway)
- Replaced MAF sensor
- Sprayed Throttle Body cleaner on all vacuum connections while can is idling, but no luck.
I know that the O2 sensors are past due but from what I gathered a faulty O2 sensor doesn't cause this issue. But maybe someone has a different experience? Should I replace at least the front O2 sensor?
My lost resort at this point is to see if I can find a smoke machine to blow the smoke in the PCV system to see if I can find another leak.
Anybody else have an idea what to do?
1997 850 NA Wagon - 261,000 miles - Is no longer
2004 V70 NA Wagon - Saved my life
2004 S80
JeffHicks
Year and Model: 1989 240 Wagon,
Post by JeffHicks »
Are you clearing the code with a scanner, or just waiting for it to go away? If you're just waiting for it to go away on its own, that's going to take quite awhile.
If you don't have a scanner that can clear the codes, you can clear them by disconnecting the negative battery cable and leaving it disconnected for half-hour. Just know that you'll have to re-code your radio.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
dejongmc
Post by dejongmc »
I have a OBD scanner to read the codes and to clear the codes.
I cleared it a few times but P0172 keeps coming back.
2004 S80
rmmagow
Year and Model: V70 1998
Post by rmmagow »
Is it a Bosch MAF sensor? If yes, check the wiring closely. you may have a connector problem.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
dejongmc
Post by dejongmc »
Yes, it is a brand new Bosch MAF sensor.
I cleaned the connectors.
I also replaced the distributor cap and rotor.
2004 S80
rmmagow
Post by rmmagow »
Sometimes the connector gets sort of worn out a bit and needs to be attached via like a velcro strip to the housing to help the connection stay in place. There's an article/pictures here that better describe what I am talking about. on my 98 V70 I had to do this and the p0172 then went away. My v70 is a turbo though but I think the MAF thing is a common to all issue.
Is your fuel pressure too high? Pressure regulator working correctly? I'd seriously consider the O2 sensor at this point too.
dejongmc
Post by dejongmc »
Does anybody know where you can rent one of those smoke machines to find vacuum leaks, here in Houston?
2004 S80
