1994 850 Should I buy it
tryingbe
Year and Model: None
Been thanked: 26 times
Re: 1994 850 Should I buy it
Post by tryingbe »
Jazzop wrote:My opinions (admittedly biased in ways that may not be relevant to you):
1. I would avoid any 850 earlier than 1996 due to the quirky electronics/engine management system in the pre-OBD2 cars.
You must know something I don't, because I plugged a 97 R ECU into my 94 wagon and it works just fine.
erikv11 wrote:
perks1 wrote:Thanks Matty Moo and Erikv11 for your thoughts. Keep 'em coming. What do you mean by quirky? More work and tempermental?
The 94 models have a different intake manifold, and all (?) have EGR which is a big pain at 20 years of age. By 95 Volvo had hit their stride with the 850, those only suffer from having EGR; the 96's and 97's are the best IMHO.
You can disabled / get ride of the EGR by simply using a 96 or 97 T5 ECU on a 94/95 turbo car.
85 GLH, 367 whp
00 Insight, 72 mpg
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Then you should get a SAS error.
Has thanked: 292 times
Been thanked: 765 times
tryingbe wrote:If two things differ, then changing the parts that don't match can make them similar.
Yep, and that's a good reason to list the differences.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
tryingbe
Post by tryingbe »
rspi wrote:Then you should get a SAS error.
Negative on that. No codes present.
I have no idea what you're trying to say.
94 intake manifold is basically the same as 96, with the exception have 94 manifold is machined for the EGR valve. I looked at them side by side a while back.
85 GLH, 367 whp
00 Insight, 72 mpg
Ben850
Been thanked: 7 times
Post by Ben850 »
Early '94 had the VVIS intake manifold like the '93.
VVIS Has the vacuum actuator shown.
vvis manifold top.jpg (57.4 KiB) Viewed 800 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
tryingbe
Post by tryingbe »
Ben850 wrote:Early '94 had the VVIS intake manifold like the '93.
That manifold didn't come on cars with turbo.
85 GLH, 367 whp
00 Insight, 72 mpg
Ben850
Post by Ben850 »
The car in question here is not a turbo.
perks1
Year and Model: 850 1994
Post by perks1 »
Hi everybody,
Thank you all so much for your invaluable advice. My apologies for taking a long time to post again -- it's been a bit too busy. As it turns out, I was not able to go and see the car. In the meantime someone else came and bought it. However, based on what the information you all shared, I think it probably was not a great loss. I will probably look for a slightly newer car, say 95-97 or go for an S70 or V70 from 1998 with over 100,000 miles that has had all the work done. In the meantime, my Honda Accord is now working fine again, so I may not need to by anything right away and can afford to take my time and be picky until I find just the right one. When I do, I will probably be back asking for further advice. Thank you all for being so welcoming and for the education.
