I think the evaporator has packed it in!!
This topic is in the MVS Volvo Repair Database » Project: Unclog the Evaporator Drain and drain hose (A/C)
Hojo_Rider
Year and Model: XC-70, 1999
Re: I think the evaporator has packed it in!!
Post by Hojo_Rider »
I should have clarified..there is also a nice leak coming in to the passenger floor. Similar to the other leaks described in this thread. It is not the sunroof or rain cover.
Hojo_Rider
And to confirm (sorry for the multiple responses)...that longer hose is the drain from the evaporator? Is that consistent this diagram? What is the #13 and #15 drains? Thanks again!
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
Could be dealing with one of two situations; a leak in your heater core, which would show in low coolant levels & a sweet smell in the cabin, or a leak from where the fresh air enters the cabin, which I believe is #10 in the image above.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
Hojo_Rider
Thanks...I will continue to investigate.
luckykolo
Year and Model: s70 1998 Base
Has thanked: 14 times
Post by luckykolo »
anyone knows where exactly water exits, underneath the s70 98 Base? My AC drains, but I have lots of rotten metal right next to the catalytic converter. I think it's related to the AC water.
Has thanked: 1505 times
Been thanked: 3817 times
luckykolo wrote: 24 May 2019, 17:24 anyone knows where exactly water exits, underneath the s70 98 Base? My AC drains, but I have lots of rotten metal right next to the catalytic converter. I think it's related to the AC water.
Item 30 in this picture. Its about 15 cm forward of the bottom edge of the climate unit, roughly, under car.
Screen Shot 2019-05-24 at 8.09.46 PM.png (357.33 KiB) Viewed 706 times
luckykolo
Post by luckykolo »
ok, just inspected it. So it drains directly on the shield over the catalytic converter, then some of the water ends up trapped between my passenger side shield mounting meeting the flexible shield over there. The mounting has rotten away. Huge chunk of the floor is rotten in that place. Weird design, unless it is not an original set up?
luckykolo
Post by luckykolo »
even better pick
