Looking to do a big bore NA intake and throttle body swap on my 855T.
Anyone know which MY's of the v70's had EGR and which didn't? I can't find info on our pal G, and it seems random as to what I find on eBay.
*Note, my car is Non-EGR
EGR/Non-EGR intake manifolds, v70's years?
futureboycolin
- Year and Model: 1996 850 Turbo Wagon
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I don't believe any V70 had EGR.
futureboycolin
But all the NA v70's did?
I'm looking for an NA intake from a v70, or a 96+ 850 (I think) without EGR to swap in.
1996 855T, "Ol Burgie"
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
Even if you grab an N/A intake with an EGR attached, Volvo makes a part to plug it (#271778) it runs about $20 at the dealer. It includes a gasket and a plate with 2 bolts. If you use the N/A intake you also need to tap 2 additional ports. The one one the front of the intake for the PCV system and a 3rd one on the front for the fuel line. Take a look at the attached diagram. This is a turbo intake, the n/a intake will not have the port labeled #4.
- turbo intake.jpg (71.44 KiB) Viewed 2388 times
futureboycolin
Damn, so it would just be easier to bore out the throttle body inlet on my current manifold?
- Has thanked: 292 times
- Been thanked: 765 times
1996 was the last year with EGR.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
I don't think so, I think you had the right idea since your car is not EGR. Just get a newer NA manifold, non-EGR, and you are good to go.futureboycolin wrote:Damn, so it would just be easier to bore out the throttle body inlet on my current manifold?
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
shaker_chi
If I were you, I would just bore out your existing intake, pick up a n/a throttle body and a 960 plate. I'm not sure if it will improve performance on a turbo, I have read mixed reviews. I have the 960 plate on my 1994 n/a 850 5 speed and it did make a noticeable difference, especially under 3,000 rpm's. Go to the Snabb website if you need the components. They claim an increase of 10hp, but I would be skeptical since they sell the kit. Good luck.
futureboycolin
I'm really just looking for a peppier throttle response in the 3k and under RPM range off the line.
So if I find a Non-EGR NA intake, will I still need to tap it for the vacuum lines?
Seems like 6 of one, 1/2 dozen of another. Either I have to drill for the vacuum ports, or bore for the throttle body...
shaker_chi
Yes, you will still need to tap the 2 lines even if you get a non egr n/a intake. Sorry!!! Not that hard though. You can pick up a basic tap and die kit at Harbor Freight for $15 and since the intake is aluminum, it's a fairly soft metal.
