You can stop it whenever you want.
Why are people not hooking up directly to the posts on the battery? I did it all last winter to keep a dying battery going with no problems; no disconnecting required, simply pop the hood attach the alligator clips to each post and let it sit over night.
1995 850GLT Battery Terminal-Ground?
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Re: 1995 850GLT Battery Terminal-Ground?
viper69
- Year and Model: 850GLT 1995
- Has thanked: 70 times
- Been thanked: 2 times
Thanks! I kept the battery cables on because I'm rushing around getting ready for something. No time to take cables off. Appreciate the response!! If I wasn't running around like a chicken w/head cut off, I'd pull the cables off or battery out.polskamafia mjl wrote:You can stop it whenever you want.
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
polskamafia mjl
Sorry, I should have been more clear. I didn't take the cables off the battery either. I simply opened the hood and attached the alligator clips to the battery, battery cables in place and all. Maybe I'm reading it wrong but it sounds like other people are getting pretty involved.
viper69
Gotcha...The battery is up to 80%, so all is well, for now hah. Thanks everyone.polskamafia mjl wrote:Sorry, I should have been more clear. I didn't take the cables off the battery either. I simply opened the hood and attached the alligator clips to the battery, battery cables in place and all. Maybe I'm reading it wrong but it sounds like other people are getting pretty involved.
Volvo 850 GLT 1995
- Has thanked: 1502 times
- Been thanked: 3817 times
Doesn't matter where you connect, sorry. I was having a pompous jerk post moment.
Make sure you wiggle those teeth on the roach clips.....I mean alligator clips......so you get contact.
I hard wire my battery tenders with circular lugs bolted to battery to avoid issues with connects
viper69
It's working fine. Battery was below 80%, now it's a 100%, agree w/the alligator clips.abscate wrote:Doesn't matter where you connect, sorry. I was having a pompous jerk post moment.
Volvo 850 GLT 1995
- 645 Views
Last post by jblackburn
- 2079 Views
Last post by db130
