1998 V70 AWD OBDII Live Data check
TheLoneAviator
Year and Model: V70 1998 AWD
Post by TheLoneAviator »
Can someone advise if this data is in the ball park?
calc Load 1.9%
ECT 201*F
RPM 840
Spark ADV. 10*
IAT 100*F
MAF 0.670
TPS 11.3%
Air Status off
o2s b1 s1 0.4 to 0.840 varies
STFT b1 s1 6.2% varies
o2s b1 s2 0.095
STFT b1 s2 37.5%
PTO status ON
thanks in advance..
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
You are idling warm, the STFT =37.5 is way way too far from ball park!
I would look for possible unmetered air ingress downstream of the mass meter (like vacuum leaks)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
TheLoneAviator
Ok, Thats what I wondered. This may be related to my P0442 post. I may just take it to the independent Volvo guy. save me the headache.
regent
Post by regent »
You could hunt most vacuum leaks without having to pay someone else - vacuum hoses at the age of your car are on the top of the offender list - just to begin with.
2015 BMW 335i
TheLoneAviator
I'll start that this w/e. See what I find.
TheLoneAviator
I found a vac line to nowhere off the left side of the intake. According to the diagram if I read it right, it should goto the flame arrestor PCV under the air box. but I don't see it. see pics. I also found a few presents under there.(Maybe the arestor PCV was removed?)
Present left by someone
Vac line from Left side under intake to nowhere
Looks like it supposed to go over here?
regent
Post by regent »
It's so nice that that 'present' did not land on the starter solenoid terminals... lucky you! :shock:
I will need to look up your vacuum and PCV lines routing when I get in my VIDA, yours is different from mine; hopefully someone may be able to chime in sooner.
2015 BMW 335i
TheLoneAviator
Yeah I don't have a good diagram either. The TCV I don't think is right either, I need to verify the routing of all these.
I did replace the Purge valve & the rotted lines to that. I think all my other issues are these vac lines routing.
TheLoneAviator
Ok, On this diagram, I need to verify where the following lines go.
#20,
#18
TheLoneAviator
And ALSO, where do I plug in a boost gage for test so I can monitor it?
