...and the saga continues
Horribly jet lagged, I did a half day at work and went home, deciding to tackle the driver CV joint
I had the whole steering knuckle off in 45 minutes - including having to zip off the ball joint bolt and nut with a grinder.. ????
The Inner CV joint on the 1999 manual T5 is a conventional CV joint with outer race on the trans, cage, 6 balls and inner race splined onto the driveshaft.
The pictures tell the story..Im going to have hunting for this guy Im sure.
1999 V70 T5 Driver side CV joint axle repair, pix
- Has thanked: 1504 times
- Been thanked: 3817 times
Re: 1999 V70 T5: CV joints are different !!
Update. Got a pristine used axle from Erie VoVo for 95 USd delivered, and 90"minutes later the t5 was back on the road with all new suspension and wheel bearing.
Vroom vroom vroom
Pictures to come.
Vroom vroom vroom
Pictures to come.
- dosbricks
- Been thanked: 2 times
Cool--so accidently and through no fault of my own, I was correct about needing a new axle.
I've had stuff shipped down here to TX from Erie VoVo and never been disappointed.
I did it pounding on the end of the driveshaft to knock it out of the knuckle. No way anything else would break that cage.
- Has thanked: 2652 times
- Been thanked: 1245 times
Five posts split off of this topic went here: 1999 V70 T5 manual trans drain fill plug pictures
