1999 V70 T5 Driver side CV joint axle repair, pix
Has thanked: 1502 times
Been thanked: 3813 times
Re: 1999 V70 T5: CV joints are different !!
...and the saga continues
Horribly jet lagged, I did a half day at work and went home, deciding to tackle the driver CV joint
I had the whole steering knuckle off in 45 minutes - including having to zip off the ball joint bolt and nut with a grinder.. ????
The Inner CV joint on the 1999 manual T5 is a conventional CV joint with outer race on the trans, cage, 6 balls and inner race splined onto the driveshaft.
The pictures tell the story..Im going to have hunting for this guy Im sure.
Another great use for zip ties - holding up the caliper
Side view - Ugh - broken cage
Almost passable from above  :-)
Inner joint on shaft ok - no circlip
Inner joint race on transmission - ok
After 16 years, can still read part number on driveshaft!
Update. Got a pristine used axle from Erie VoVo for 95 USd delivered, and 90"minutes later the t5 was back on the road with all new suspension and wheel bearing.
Vroom vroom vroom
Pictures to come.
dosbricks
Post by dosbricks »
Cool--so accidently and through no fault of my own, I was correct about needing a new axle. :P
I've had stuff shipped down here to TX from Erie VoVo and never been disappointed.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
looks ugly. any idea which part of the job ate the cage?
I did it pounding on the end of the driveshaft to knock it out of the knuckle. No way anything else would break that cage.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1242 times
Post by matthew1 »
Five posts split off of this topic went here: 1999 V70 T5 manual trans drain fill plug pictures
Also -> Amazon link
