98 xcv70 thing on top of exhaust downpipe
thaedge
Year and Model: xcv70 1998
Post by thaedge »
Hey, on the top of my exhaust downpipe leaving the turbo is a silver tube leading to a valve and then has a hose going to the front right of the car to what I assume is the emissions air pump? What is the part coming off the downpipe called? Is it vital, or can I plug the bung on the downpipe and plug the airpump hose?
I'm trying to remove the exhaust, and I can't get this detached from the down pipe because of rust, I think I'm going to have to break it off to get the exhaust out. I can't find where to buy a replacement, but I'd rather not anyways, I'd rather bypass it and be on my marry way.
Thanks
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
SAS/air pump check valve.
You could plug it, but you'll need to do the SAS delete.
https://www.matthewsvolvosite.com/forums ... =31528&f=1
'98 S70 T5
2016 Chevy Cruze Premier
thaedge
Post by thaedge »
Thanks, is there a way to remove the cat/downpipe while leaving this intact since there it's not coming loose? Or do I just need to cut it off.
jblackburn
Tried soaking it a few times with PB Blaster?
Might be easier to get off if it's warmed up a little bit too.
'98 S70 T5
