2005 XC90 Replaced FPS car sputters but wont start
cabdoctor
Year and Model: 99 s80 05 xc90
Post by cabdoctor »
My xc90 sputtered and died while in traffic. I could restart it onlly to sputter over to a parking lot and have it die and not restart. It threw the Fuel Pressure Sensor CEL so I went ahead and replaced that. Now at this point I can get the car to turn over, I can hear it wanting to catch and in fact it even catches for a few seconds but it refuses to fully start. Any ideas? Thanks guys
Stravlr
Year and Model: 2004 XC90 T6
Post by Stravlr »
Fuel Pump? Plugged Fuel Filter. The sensor (while could have been bad), is the measurement result of an action. Just my 0.02.
Scott
cabdoctor
Post by cabdoctor »
I can hear the pump running but getting almost no pressure readings from either test point(near the filter or on the rail). If I disconnect the line near the filter and turn the key to the on position I get a steady stream, not sure how hard it should be spraying out.
cabdoctor
Post by cabdoctor »
Here's an update:
Saturday my XC died in town. Was able to restart and stutter if off to the side of the road. It never restarted. Since then
Car would turn over but and sputter a little but never "catch"
No pressure at the rail or at the fuel filter.
When the fuel line is disconnected and the the pump is "jumped" no fuel comes out. Although I can hear the pump running.
No voltage at under hood fuse #9 for the fuel pump when the key is switched to own(not sure if there should be but just checking everything).
Can only jump the pump from the the pump itself. If I try to jump the pump from the White and white/black wires on the PEM connector I get nothing. Even though I used a multimeter to determine both wires are good.
Brand new Fuel Pressure Sensor.
Anyone have any ideas?
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Yes, the Fuel Sytem Supply Fuse # 9 (11B-9) should be hot-powered. Are you using the same schematics that I am looking at:
http://www.volvowiringdiagrams.com/volv ... agrams.pdf
If you your FP runs and delivers but you still have no pressure past the filter or at the rail, you want to check the integrity of the fuel lines and your filter (it is most likely plugged up, like it was suggested earlier)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
jimmy57
Been thanked: 322 times
Post by jimmy57 »
There two pumps and you likely are only hearing the transfer pump that runs to pump fuel over to the left side to go through the ejector pump to deliver left side fuel back to right side.
The transfer pump is not controlled by PEM.
