1997 850 wagon: Rear Defrost ?, Heated Mirrors not heating?
brian_kearney410
Year and Model:
Post by brian_kearney410 »
Greetings-
When using the Rear Window Defrost/Side Mirror function, the rear window defrost works (save for one line - is that one line repairable?), but neither side mirror seems to warm up at all. I realize it's quite cold out recently, but I was hoping for some amount of melt/defrost. Is it possible to replace the heating element in the mirror(s) or do I consider replacing the entire mirror unit?
Thanks,
Brian
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Yes. There is a product, which your local car parts shop should have, which can be painted onto the glass to join the two ends of the bad line. Sorry, but I can't remember its name.
As for the mirrors check to see if you have 12v at the glass. If not you can replace the glass.
Bill.
Edit: http://www.frostfighter.com/
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Svenska 850 Wagon
Year and Model:
Post by Svenska 850 Wagon »
I have the same issue. My Rear window works but neither of my side mirror's work. Is this a common issue where both would go at the same time?
1995 Volvo 855 GLE 262,000Kms
1992 Subaru SVX 82,000 Miles
1981 FIAT Spider 194,000Kms
1981 VW Westfalia 164,000Miles
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Svenska 850 Wagon wrote:I have the same issue. My Rear window works but neither of my side mirror's work. Is this a common issue where both would go at the same time?
I very rarely hear of the heated mirrors not working...much less both at once. I would look for a common ground, fuse, etc. before thinking that the mirrors themselves are defective.
billofdurham
The heated rear window and the mirror heaters both work off the same fuse #11. They also both work off the same relay, although off different terminals on relay #13 on the central electrical unit. The rear window is terminal 87 and the mirrors 87B.
Therefore, as MIJ suggests, you will probably be looking for a bad connection or ground somewhere.
Bill.
Previously:
brian_kearney410
Year and Model:
Thanks to Bill and MIJ!
Man I love this site.
Netrix
Year and Model:
Post by Netrix »
On my car and my friends 850 our driver side mirror does not work.
His car also has alot of bad connection on his back window due to a amatue tinting job. When they were trimming the tinted plastic material off they sliced through a few of his defrosting connections on his window. They're are products however that you can pick up at your local auto parts store that allow you to paint on some repairs where the lines are sliced at. I think the kit is like $5-10 if I remember right.
1996 Volvo 850 Turbo Wagon
