98 v70 awd cruise control not working
tom4342
Year and Model: 1998 v70 awd
Post by tom4342 »
My cruise stop working recently and in several forums i read check the vacuum hose and brake switch,i pulled the battery and tray and found the servo but with no hose feeding it just 2 small ones on the servo itself and a power plug. I see no evidence of a hose going to it my question is there supposed to be or is it totally electronic?If it has a hose what manifold port does it go to?
Tom Hood
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
The hose that connects to it runs from the passenger compartment to the little pump right alongside the hood release cable. It's a plastic vacuum line.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
tom4342 wrote:
...but with no hose feeding it just 2 small ones on the servo itself and a power plug.
I don't understand this statement.
JBC2565
Year and Model: 2000 V70 XC SE
Post by JBC2565 »
My cruise control stopped working on 2000 V70. Turned out to be the ABS module.
Does your trip odometer and speedometer stopped working then came back? Also my brake light came on (no ABS light) and orange arrow flashes.
tom4342
Post by tom4342 »
Nice video however doesn't show where that vacuum hose goes that feeds the unit under battery tray
Tom Hood
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The pump under the battery tray creates vacuum which pushes a diaphragm unit close to the accelerator pedal. The vacuum line from that pump snakes directly to the diaphragm. The diaphragm has a bracket which is directly connected to the accelerator pedal. The vacuum is teed for a braking switch which is located directly above the brake light switch. This is called the cruise cancel switch.
tom4342
Post by tom4342 »
thanks
Tom Hood
Has thanked: 1611 times
Been thanked: 4071 times
JBC2565 wrote:My cruise control stopped working on 2000 V70. Turned out to be the ABS module.
Different beast on the ME7 cars from 1999-on. Once Electronic throttle body came in, the cruise function integrated nicely into this system, and the vacuum pump, hoses, and stuff under the battery disappears.
If the ABS module goes bad, the electronic control unit (ECU ) inhibits cruise function as a safety measure.
tom4342
Post by tom4342 »
replaced the hose works but seems weak
Tom Hood
THeOldMan
Year and Model: V70 1998
Post by THeOldMan »
Brake switch, check. Accelerator linkage arm, check. Vacuum hose near battery, sliced! I reconnected the ends using a piece of windshield washer hose. Cruise control, works! Wish I had known about this 7+ years ago when it quit :-)
