2005 xc70 tranny fluid change interval
2008XC70
Year and Model: XC70 2008
Re: 2005 xc70 tranny fluid change interval
Post by 2008XC70 »
I like to pull the drain plug on the transmission every other oil change, so every 15k miles or so. Drain about 3.8 qts and add the same. This keeps the fluid nice and fresh. Obviously if you notice that the trans is getting a little clunky, change the fluid asap.
mrscullini
Year and Model: 05 XC70, 08 XC70
Post by mrscullini »
2008XC70 wrote:I like to pull the drain plug on the transmission every other oil change, so every 15k miles or so. Drain about 3.8 qts and add the same. This keeps the fluid nice and fresh. Obviously if you notice that the trans is getting a little clunky, change the fluid asap.
can you do this without resetting the fluid counter?
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 603 times
Post by vtl »
mrscullini wrote:can you do this without resetting the fluid counter?
If you have external ATF cooler and never step on pedal to the metal for a prolonged time - probably not. Otherwise transmission counts events when ATF was at 150C/300F for 3 minutes (that's too much for mineral-based oil IMO) and starts to reduce torque converter slippage after some point. This would mean less comfortable gears shifts and reduced performance overall.
mrscullini
thanks for all the input. next weekend is slated for some tlc on the vehicle. just want to make sure i have the process correct.
1. drain fluid, measuring the drained amount
2. fill fluid, matching the drained amount
3. reset the fluid counter using vida/dice
that's it, right?
btw, new to vida, can somebody point me to a procedure for resetting the fluid counter?
