1986 240 DL Fuel pump fuse bypassed?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
mhgreen
Year and Model: 240 DL 1986
Post by mhgreen »
Hello all. Thank you in advance for your guidance here.
I was attempting to replace the fuel filter on my 240. I removed the main fuel pump fuse (#6), and waited for the engine to stall…only it didn't, and wouldn't after 10-15 minutes of running. I purchased this car used (very used), and I have no knowledge of previous service, shortcuts, bypasses, tricks, etc. that have been done on the car. Am I correct to assume that the fuel pump fuse was bypassed? How can I know? Can I change the fuel filter without shutting down the pump this way?
Matt
“Some cannot loosen their own chains and can nonetheless redeem their friends.”
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
mhgreen wrote:I removed the main fuel pump fuse (#6)
Remove fuse #4 next time; #6 thru #10 are hot all the time.
rgk
Year and Model: Gray 88 245
Post by rgk »
Yes, if I remember correctly, the right side of the #4 fuse terminal goes to the main pump, and the left side of the #4 fuse terminal goes to the primer pump, or vice-versa. It's weird.
rgk -- was dickdeadly
mhgreen
Post by mhgreen »
How long should the car take to stall once the fuse is removed?
rgk
Post by rgk »
Less than ten seconds.
mhgreen
Post by mhgreen »
And if it doesn't stall…?
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
mhgreen wrote:And if it doesn't stall…?
Then your fuel pump relay wiring may have been rewired.
1988 Volvo 760 Turbo Wagon
rgk
Post by rgk »
Would this also apply to having a different year/model's relay connected?
rgk
Post by rgk »
Try removing fuses 4 and 6...
93Regina
Post by 93Regina »
rgk wrote:Would this also apply to having a different year/model's relay connected?
Really getting off topic on this topic...a relay is required, unless one wants to fry their ignition switch.
Now, does OP know where relay is found, or even have an understanding of relevant electrical circuits?
