V70 Radio security code lost
Hi, Was changing car battery and radio was of corse blocked by the security code. I have lost the code card , never used it before, so i have no clue what it could be. Is there any way I can fix it myself ?
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Call your dealer with your car's VIN# and they'll give you your code.
MadeInJapan
Oh, also if you have all of your car's documentation, you might find a plastic card in your packet...looks like a credit card. There is a 4 digit number on that card (I don't believe it says it's your security code, for security reasons), but anyway, if you find that card, use the 4 digit number and that should work. Otherwise, some people write the number in the back of their owner's manual or if you pull the radio out, on the top of the radio with a permanent parker. Anyway, if you don't find it anywhere, then the only way is a call to the dealer. Good luck!
zenmervolt
- Year and Model:
If you do have to call the dealer to get your code, then as MIJ suggested either write it down in your owner's manual or write it on the unit in permanent market. In all honesty, it's not likely that a factory stereo will be stolen out of your car, thieves usually target aftermarket units, so writing the code on the radio itself isn't terribly risky.
'98 Volvo S70 T5 SE
'86 Porsche 951
'76 Porsche 914
'86 Porsche 951
'76 Porsche 914
