1996 850 Brake Bleed Nipple/Rubber Line Questions
TBrown00
Year and Model: 1996 854 GLT
Post by TBrown00 »
I'm preparing to flush my brake system next week using cn90's 1-man method (https://www.matthewsvolvosite.com/forums ... =1&t=29243) and was looking at my bleeder nipples last night. On one of them, the protective rubber cap has mostly disintegrated leaving no protection. Is this something that should be replaced? Could this cause any issues I should know about/prepare for before starting this project?
I also noticed that a couple of the flexible rubber lines are cracking at their joints. Should these be replaced or is this normal wear and tear and doesn't affect anything?
Thanks!
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Any auto parts store should carry replacement bleeder screw caps and they are dirt cheap. I replace them if they are at all bad but they really don't do that much. They aren't mission critical.
The cracking on the brake lines is typical and it is just the sheath that is cracked. If there is a bulge then it is a big deal but all of mine have cracks to various degrees and I don't lose any sleep over it.
TBrown00
Post by TBrown00 »
Ozark Lee wrote:Any auto parts store should carry replacement bleeder screw caps and they are dirt cheap. I replace them if they are at all bad but they really don't do that much. They aren't mission critical.
Awesome. Good to know! I was hopeful it wouldn't make the bleed screw more likely to be seized.
Been thanked: 504 times
Post by cn90 »
Brake hoses are cheap, about $12 for FTE brand, which is OEM.
See the DIY below...
DIY: 98 V70 Brake Hydraulic Overhaul (Hoses, Seals, Parking)
https://www.matthewsvolvosite.com/forums ... hp?t=37721
I have a friend who ignored the brake hoses on his Honda Accord, one day he lost all brake on a downhill slope, almost killed some pedestrians...Luckily he hit another parked car. That was a story 20 years ago...
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
The front brake lines on my '97 855 GLT had visible cracks for a long time (~4-5 years) before they started to seep brake fluid. After having done the job, I realized it wasn't as hard as I had been imagining to change lines and pressure bleed the calipers. I wrote up a short DIY guide here:
https://www.matthewsvolvosite.com/forums ... =1&t=58362
Brake Line 01.jpg (106.77 KiB) Viewed 959 times
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I believe ATE is OEM not FTE. I have the same cracks, scheduled for replacement. I got the ATE line from my parts supplier.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Has thanked: 311 times
Been thanked: 817 times
mecheng wrote:I believe ATE is OEM not FTE. ...
I think so too.
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
I put whatever fcp sells on last month. The sheath was cracked and I had to replace a caliper anyway. It's a pretty quick job.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Post by cn90 »
Re: ATE vs FTE...
I have been using FTE brake hoses for some 15 years in my BMWs and Volvos, zero issues.
On some websites, the vendors say ATE/FTE (implying same company).
On others, they seem to be separate companies.
I don't know much about the corporate thingy, but all I know is FTE is excellent product.
FTE is used widely in Volvo, BMW, Mercedes (brake hoses, clutch hoses, clutch master/slave cylinders etc.).
Quality wise, I think FTE hoses are way up there, same as ATE in terms of quality.
Been thanked: 4068 times
I did a bit of googling this morning and it looks like FTE group and Teves (ATE) are different. Both have a long history of supply chain to high end Euro markets, though.
