Hi Guys,
My nephews are stranded in NE. Pa with a bad alternator. How many hours will a NA 850 run with a new fully charged battery with all other voltage drains shut off like headlights, radio and heater blower? MY hope is to get them back to Ohio. I have a serviceable alternator in the basement. The shop where they are stranded is quoting a price of $600.00 for alternator replacement. This does not count the $220.00 battery they have installed.
Thanks
1994 850 battery life with out alternator
- Been thanked: 4068 times
I'm going swag this at
5 amps fuel pump
2 amps for coil
5 amps stuff I haven't thought of
80 amp hour battery/12 amps = 6 hours to full discharge
At 3 hours battery voltage will drop to where things will stop working.
3 hours max, no lights , stereo, wipers
5 amps fuel pump
2 amps for coil
You could have them buy a 10'amp charger, extension cord, and motor back over a couple of days
Let's see if anyone has a better number than my SWAG, too
We didn’t get a better swag but I just wanted to comment that no one has ever succeeded in getting home running a Honda generator in the back seat with a 12 v feed to the battery and posted it here.
- Year and Model: Lots
- Been thanked: 128 times
No abscate but I did try to get a portable home a/c unit running in my backseat by using a 1000W AC inverter. Unfortunately the power from my inverter wasn't "clean" enough or it was badly rated to run the unit and it wouldn't operate.
Ah , but Canadians are subject to indignities as inpetulant toddler neighbors, half price medical care for everyone, and DRLs....daytime running lights,,which drain the battery fast.
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
I had an alternator die on me and I bought a new battery. It got me home the last 100 miles. Since I had to get to work the next day I alternated batteries. I charged one while I was at work and then swapped it out each day until I put in a new alternator. Turn off EVERYTHING you do not need when driving without an alternator. Don't drive at night. Headlight will drain your battery fast.
Good luck.
Good luck.
- wizechatmgr
- Has thanked: 45 times
Don't lie, that was your anti-theft system. And a good system it wasshaker_chi wrote: 25 Nov 2017, 20:28 I had an alternator die on me and I bought a new battery. It got me home the last 100 miles. Since I had to get to work the next day I alternated batteries. I charged one while I was at work and then swapped it out each day until I put in a new alternator. Turn off EVERYTHING you do not need when driving without an alternator. Don't drive at night. Headlight will drain your battery fast.
Good luck.
- 682 Views
Last post by E Showell
- 354 Views
- 564 Views
Last post by 122sPhil
- 11 Replies
- 3711 Views
Last post by wizechatmgr
- 20 Replies
- 7469 Views
Last post by tonie
