Hey all, I recently purchased a T5M. After a few days, I have noticed a jingling(think keys or chain rattle) sound under the hood. The car does this all the time. Other than that, the car performs as it should. Does anyone have a clue into what this may be?
I've searched through here and haven't found anything so, forgive me if this has been covered.
All ideas are truly appreciated.
2000 S70 T5M jingling noise when car is running
Alabamabricklover
- Year and Model: 98 V70R
I know this is vague. I will try to post a video later so people can hear the noise.
- Has thanked: 2197 times
- Been thanked: 1850 times
Does it do it all the time? As you have a manual trans, does it continue when you depress the clutch even at rest?
If it stops or sound changes when clutch depressed it could be the release bearing in the clutch failing.
Alabamabricklover
It does it all the time.
- Been thanked: 4064 times
It's time to get out the car coloured piece if garden hose and isolate the noise
Check pulleys and accessories on the serpentine belt first.
Or even remove the serpentine belt to see if any of the items are at fault. Sometimes I find it hard to isolate noises of items on that belt as they are all mounted to an aluminum frame which transmits the noise to all components. Although, for this noise the old pipe stethoscope should be good!
- 92 Replies
- 25992 Views
Last post by WhatAmIDoing
- 1005 Views
- 341 Views
Last post by phils94850
- 18 Replies
- 4072 Views
Last post by tryingbe
- 821 Views
