2002 S60 Immobilizer elements?
rohran
Year and Model: 2001 T5
Post by rohran »
I have an S60 with an immobilizer problem. I have a wrecked S60 of the same year and model. Has anyone successfully swapped the electronic modules from one car to another and made the car run without immobilizer problems? If so, what modules do I need to swap?
Richard in Provo, UT
doublebug
Year and Model: XC90 2007 D5
Been thanked: 7 times
Post by doublebug »
What is the issue with immo?
If you have questions about Volvo firmware ask me. I may know an answer :)
rohran
Post by rohran »
a) the key seems to be going bad as far as fitting the lock, and b) it starts and runs for 2 seconds
doublebug
Post by doublebug »
If you have Dice I can solve these issues.
rohran
Post by rohran »
I don't think Dice can fix a worn out lock cylinder. That's why I want to swap everything.
doublebug
Post by doublebug »
Yes, but this should :)
rohran wrote: it starts and runs for 2 seconds
So look for new ignition lock (with keys) + all other locks.
Cut new keys with place for transponder.
Disassemble old keys take the transponders and insert them to the prepared keys.
That is minimum.
if you want more see PM.
