USE OEM ONLY for these:
DARK_BLU
Year and Model: 850 GLT 1996, NA
Re: USE OEM ONLY for these:
Post by DARK_BLU »
It's good to know that I'm not as paranoid as I thought I might be for replacing worn parts with Volvo/OEM parts. The shop I take my 96 850 GLT N/A to for repairs and maintenance only uses Genuine Volvo/OEM parts. I was considering that MSD Ignition over the Bosch, but since I recently had the Distributor Cap and Rotor replaced with OEM/Bosch, I'll stick with Bosch for the Ignition. This thread answered that for me. Thanks, guys!! :mrgreen:
96 Volvo 850 GLT/NA-Green @312,298 miles
Stage 0 Tuneup w/Cold air side/open flap air box mod
Pro Parts Sweden Exhaust manny/DEC Cat/Starla Exhaust/SS Tip
Hard Rock guitarist with Solo project, driving a Swedish Death Metal Machine. http://darkblu.com
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
I'm going to say OEM only for front sway bar end links due to a recent catastrophic failure of IPD "Heavy Duty" end link. I'd also say OEM only for radiator expansion tank cap.
Going in the other direction, I'd say OEM for replacement battery cables is a waste of money. Better to obtain custom cables from a place like genuinedealz.com. Those will be a heavier duty spec. than OEM.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Been thanked: 468 times
Post by cn90 »
UPDATE May 2015:
- For engine seals (cam seals etc.), stick to Corteco.
- I just found out by myself (comparing a brand-new Corteco seal vs a Volvo OEM cam seal) that Corteco is identical to Volvo at a fraction of the price.
Example 1998 S70 Front Cam Seals:
* Corteco: $9
* Volvo OEM: $19
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Now that I recall the WS series Bosch inserts for some 1999 and all 2000 cars have disappointed because of crush in the filter which has lead to sizable holes in the filter media. This has happened twice on 2 different vehicles in close succession.
So far I've used Mahle (OX-149D) MANN (HU 819 X) and more recently K & N red inserts (PS 7002) with no issues.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
cn90 wrote:UPDATE May 2015:
* Corteco: $9
* Volvo OEM: $19
And If you buy a Erling seal it says Corteco on it. I believe but haven't confirmed, Erling cam seals are now made by Corteco
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
How about the rear traverse arm mounts/Links? (4 in all)
I wanted to use OEM, but all 4 after market parts were as "cheap" as only 1 OEM part (~170€ or something). Maybe I will regret it, but I still think OEM is way to expensive in this case - would have cost about 3x more.
850 T5-R '95 auto Image
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
Maybe I missed it, but still not sure if Sachs spring seats (for 850) are OEM. Comments?
Has thanked: 1502 times
Been thanked: 3813 times
Sachs struts were OEM on my 1999, so I imagine its likely they made the seats too.
Yep Sachs are spring seat manufacturers for Volvo. It's further back in the thread too I believe, or was that the top mount?
Has thanked: 292 times
Been thanked: 765 times
I didn't go back and check the thread but strut top mounts were INA from the factory and that is a good one to go OEM only on. There may be decent quality aftermarket ones now but the INA part lasts so long, I have never installed anything else.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
