2007 V70R Rear Door wiring Failures, wont unlock
V70RR
Year and Model: V70R 2007
Post by V70RR »
severe wire failures, rear door wont open and wipe stops. Check wire harness at hinge area. I found 8 broken wires and 3 exposed but not completely broken. Door is hard to open when it will not unlock.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
This is a flaw that Volvo hasn't been able to design out of their wagons for 30+ years.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
It's a flaw all makes have in their wagons. I have repaired or replaced wires in Explorers, Expeditions, VW, BMW, Mercedes, etc, etc
i have repaired the original wire where test lead wire (more but much smaller strands inside the insulation) was used and even that fatigued and broke.
The mini-van way with spring loaded contacts and contact pads is a great way to do it but it wouldn't support power tailgates and other items in tailgates that work with it open.
V70RR
Post by V70RR »
The wire loom gets bent sharply and smashed between hinge and roof, my fix may only last a while so a better solution is needed. At least I learned how to open the door when the lock has no power.
