98 vovo s70 Rack and pinion replacement
cturner38
Year and Model: S70,1998
Post by cturner38 »
Can anyone out there tell help me with putting the shaft of Rack and pinion back into the steering wheel coupling? This is the place that I am stuck at the moment!
Thanks!
cturner38
chrafael
Year and Model: 1998 v70 GLT
Been thanked: 10 times
Post by chrafael »
I was able to pull mine down with a bar clamp. Make sure the splines and the pinch bolt are correctly aligned.
cturner38
Post by cturner38 »
I got the shaft in but now having an issue with the bolt/screw of the large fluid line. I posted some pics on the s80 forum because they had the rack issue! This is all I needed to do to complete the job but the bolt/screw isn't catching!
Any suggestions! I hate to take all of this apart again!
So close but want catch!
chrafael
Post by chrafael »
Are you sure that o-ring is in the right place? The line doesn't look straight enough, It has to be perfect. You may need to loosen the rack bolts some or tweak the line a little. A 3/8" drive 12 point 19mm flare socket would help to tighten it. I got one on ebay for about $20.00.
cturner38
Post by cturner38 »
I have a 19mm but have tried to get it straight by loosening the line from the top (from the pump).
No success yet!
Has thanked: 1505 times
Been thanked: 3818 times
Loosening the two pieces on a union joint is a intermediate mechanic trick. The best application is on brake calipers where it is a lot easier to start the brake unions with the caliper off the car, the mount.
Loosen the rack until you can move it by half the union diameter. If the rack calls for torque stretch bolts, use new ones. :-( you don't want the rack coming loose.
