2002 V70 T5 what is this error message?
Lou Rosenbaum
Year and Model:
Post by Lou Rosenbaum »
" Bulb Failure, position light" I can't figure out what position light means all lights seem to be working
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Tail light or front marker light. Turn knob to park light position and look closely.
Vovo_merz
Year and Model: 2007 s60R
Post by Vovo_merz »
Usually its tail lights it has 2 bulbs in each for running lights and when one of them would burn out it will bring up that message
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
Lou Rosenbaum
Year and Model:
thanks, with close inspection (in the garage with lights out) much easier to see...... lose bulb
I am a happy camper thanks again
Lou Rosenbaum
Year and Model:
jimmy57 wrote:Tail light or front marker light. Turn knob to park light position and look closely.
thanks pulled into garage lights off, much easier to see. lose bulb right rear
thanks again ( the closely ) was the key
jimmy57
Post by jimmy57 »
You may find that the bulb is actually shot. Touching a bulb with a broken filament can move the filament ends close together and they will arc and temporarily fuse but will soon fail again. The reason a lamp quits and you turn it off and on and it works and to days later it goes again never to recover. If bulbs fail then get two pair and do them all or you will be back again and again as they are all the same age.
