04 C70 Shredded serpentine belt, crankshaft spins freely
dosbricks
Been thanked: 4 times
Post by dosbricks »
rspi wrote:Strange... if you turn the crank, do the cams move? I don't really understand what you are saying is going on.
If the timing belt is still on and fine, is the harmonic balancer damaged?
+1 rspi. The OP's post needs clarifying.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Ben850 wrote:Moderators?
'04 C70 would be a different forum. Wish I could help.
Actually the C70s are all P80 cars and this is the proper forum. The engines follow the P2 cars after 2000 but we do our best. They fall into the weird duck category - kind of like the '93 850s. :D
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
1.) Sorry if I posted in the wrong forum ... Pretty sure the problem would apply across the board for the earlier models too. I will post this to the 2004 area too.
2.) for those not understanding whats going on. Serp belt split a few ribs, shredded, and got caught up behind the crankshaft pulley. The timing belt did not break. Timing marks appear ok possibly/maybe 1 tooth off. When I put a socket wrench on the crankshaft it spins with no resistance at all. Car does not start.
My plan is as follows based on the replies so far:
a.) Compression test.
If compression is bad... - plan for new head or new engine.
b.) If compression is good, pull crankshaft pulley as it may have a keyway tab and slot that was damaged.
c.) I have done about 10 timing belt and serp belt changes as a shade tree mechanic and would not have done anything different. Not sure why this happened.
Will keep you all posted in a few days. Any other thoughts are welcome.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
cuhfs
Post by cuhfs »
Per Lee's post I guess this is the right place to post for this engine. Thanks
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Post by cuhfs »
Removed the timing belt cover. Pulled out the shredded belt material.In a no start situation. Will follow steps noted above.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Been thanked: 504 times
Post by cn90 »
My theory is perhaps the serp belt was put on with one rib off. Just a theory.
Or the serp belt tensioner going bad, causing mis-alignment.
This is why I always use Conti OEM belt (timing belt and serp belt) and at 140K+, I always replace the idler/tensioner pulley on both the TB and the serp belt system.
This happens all the time: the serp belt goes bad (either from belt breakage or pulley(s) going bad ---> belt ended inside the TB compartment ---> ruined engine). Not specific to Volvo but any vehicle with TB system.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I remember I had a gator back belt for another car I had, and it didn't have a continuous rubber line, it was sort of ribbed. That could cause a tracking issue
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Crank abruptly stops while the momentum of the cams continue to drive forward. My 960 had a serp belt wrap around the crank pulley that killed 24 valves 5 years ago.
Hope yours survived. I'm concerned that your car doesn't start.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I helped the owner with a compression test this morning (he didn't have a gauge and I do). We didn't bother testing more than two cylinders. Cylinder 1 didn't even move the needle of the tester from the resting, i.e., zero position. Same result on cylinder two. Didn't seem to be much point in testing the remaining cylinders. I'm pretty sure the compression tester is functioning as it should. He's weighing his options. Other than the obvious, the car is in great shape.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Ben850
Been thanked: 7 times
Post by Ben850 »
I feel badly for jumping to that conclusion.
After seeing issues with C70s over the past few years, I realize they fall into the same group as a 1993 850 GLT. Somewhat mutant.
Apologies.
Sorry to hear of the actual damage.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
