By the way, who is the recommended shop nowadays for rebuilding your Volvo head?
1999 S70 One of these head bolts is not like the others.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Been there, done that. Easy out is your best friend after finding a good, sharp reverse handed drill bit.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 312 times
- Been thanked: 818 times
Ugh. Sorry to see that.
Check this out regarding rebuilt heads: https://www.matthewsvolvosite.com/forums ... =1&t=69336
Brucebo
- Year and Model: 850 '96, S70 '99
- Has thanked: 3 times
- Been thanked: 5 times
Scuttlebutt on the web is, once the top of the bolt is broken off, tension is removed from the threads, so it should not be too difficult to remove the stub with a reverse drill and/or an Easyout. I currently have the hole filled with Liquid Wrench. I also put an exact diameter transfer punch down in the hole and tapped it with a hammer to put an exactly centered starter hole on top of the stub for the drill. I also plan to put a steel bushing in the well to keep the drill bit centered and protect the sides of well.
- E Showell
Transfer punch and bushing both good ideas, but I am here to tell you that a good, sharp reverse threaded drill bit will be your best friend. A good cut followed by an easy out of the proper size and you'll be good to go. Just move deliberately and carefully and you should be fine.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Let me guess. Back side of engine, i.e., adjacent to firewall, between cylinders 2 and 3 or 3 and 4?
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 1613 times
- Been thanked: 4078 times
Anything one can do here to prevent this nasty? Maybe getting penetrant down the threads before loosening?
Brucebo
How would one do that? Before loosening, the bolt head flange is tight against the top of cylinder head. No way to get to the threads. I suppose someone could design a head bolt with a small cylindrical hollow center shaft to serve as a temporary oil galley, with small radial galleys going out to the threads. To be filled with PB Blaster prior to removal.abscate wrote:Anything one can do here to prevent this nasty? Maybe getting penetrant down the threads before loosening?
You can get penetrating oil to tight threads with...
Time
heat
Reasonable application of shock - rattling the bolt with careful taps
Time
heat
- 15 Replies
- 3206 Views
Last post by beigg
- 1335 Views
Last post by Nevada1906
- 156 Views
- 12 Replies
- 3478 Views
Last post by CNGBifuel
- 1057 Views
