engine surging
Oldsguy
Year and Model: 2001 S80 2.9
engine surging
Post by Oldsguy »
Replaced etm with rebuilt from bba in mass..also did oiltrap a week later, now car is reving between 1500-2200 and wont stop till shut off. Could this be maf sensor?
Oldsguy
Post by Oldsguy »
Ok, changed Maf sensor..still doing it..changed battery because other was weak. Im lost..next a match and lightwr fluid.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Have you done basic tests for ETM power at connector?
Oldsguy
Post by Oldsguy »
No..not sure how to do that. Dealer installed etm 2 weeks ago, they got me nervous mentioning oil trap. So i did it figuring it was an easy diy cleaning, after putting it back together is when i experienced throttle issues. And idle issues. Gonna check again today to make sure i didnt leave something unhooked. If the idle air control valve is left off will vehicle run..and possibly cause these issues?
Large green wire at lower left of connector going to ETM is +12V , right next to it is ground (large brown wire)
Does ETM click on when ignition switch is at PosII and then click off in around 8 seconds?
Have you scanned the car for codes?
Oldsguy
Post by Oldsguy »
It does click on and off..no codes showing..and reader says no codes found. There is a service light that comes on at startup..then goes off after a few minutes. I have disconnected battery a few times while working on it..and this issue arrose after doing oil trap, before that, it ran fine after etm install and software update.
Oldsguy
Post by Oldsguy »
Im a gas, air, spark guy..this comp crap is for the birds
Is this a turbo mill?
jbkeene
Year and Model: 2000, S80, NA
Post by jbkeene »
did you use a new gasket for the ETM?
did you forget to install gasket?
Oldsguy
Post by Oldsguy »
No..2.9
