1993-240: Electrical SNAFU
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Key On - No Warning lights
Engine Idling - A dim battery light, fuel/temp gauges do not work...battery voltage 13.8V
40 MPH Driving with OD engaged - Speedometer reads 20 mph
40 MPH Driving without OD - Speedometer reads Zero, battery light bright
93Regina
Post by 93Regina »
Update:
After taking a 10 mile highway drive, I disengaged OD, and fuel/temp gauges began working, and speedometer went to traveling speed.
Back to normal now!
I fail to see how that OD Relay is related to this SNAFU, but somehow it is.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Does this car have a main head light relay similar to the one used on 88-90 760 and 92+ 960? The main relay on my 88 760 is rectangular about the size of two standard relays. When this relay was failing on my car I had all sorts of electrical problems. The head lights randomly wouldn't come on, the speedometer would randomly stop working when the head lights were on. The overdrive light would be lit even though it shouldn't have been. Replacing this relay with a spare solved the problem.
1988 Volvo 760 Turbo Wagon
93Regina
Post by 93Regina »
lummert wrote:Does this car have a main head light relay
Several months ago, I replaced this relay with a VOLVO 1307991 GENUINE OEM RELAY
When I clicked the OD button to disengage, it was instantaneous, everything back to normal.
Quartz clock worked fine, all of the time.
93Regina
Post by 93Regina »
lummert wrote:Does this car...
Symptoms:
1. OD Engaged - OD and battery lights were dimly lit; No temp reading, and a pinch on fuel gauge
2. When key switched to on position, all warning lights off.
3. Non OD Mode - Only battery light glows brightly, nothing else works on dash except clock.
Solution - Maybe fuse 16 was the issue. I cleaned its terminals, and fuse's ends
16 Parking lights (right side), Instruments and control panel lights, Shift indicator light 8A
93Regina
Post by 93Regina »
Back to square one....today, issue lasted for seven miles of driving, and then everything OK.
5ft24
Year and Model: 2005 XC90 V8 AWD
Has thanked: 20 times
Been thanked: 12 times
Post by 5ft24 »
Check grounds to the instrument cluster
93Regina
Post by 93Regina »
5ft24 wrote:Check grounds to the instrument cluster
That's an idea....I need to study/think about that OD Relay...when issue happens, it is dimly lit with OD engaged, and brightly lit when OD is off.
OD Relay provides a ground path for bulb to light up when OD is not engaged, which would suggest there is power on the bulb side.
Alternator light is lit up when this issue happens, which would normally mean the alternator is providing the ground path.
One of these days, I'm going to remove instrument cluster and fix Odometer.
