2000 S70 - Accidentally put in full synthetic oil
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Sit back and enjoy improved fuel economy.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
dosbricks
Been thanked: 4 times
Post by dosbricks »
I purchased my wagon when it was two years old and switched it to full synthetic. It took about two years for the synthetic to clean up some brown deposits inside the engine, so it doesn't happen overnight. The S70 has always been on synthetic since initial break-in.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You should have been running synthetic anyway but now at your miles check for any leaks in a few hundred miles.
If it has no leaks, continue to run it.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I'm going to stick my neck out (again)
The theory that sludge can form a leak barrier which is more effective than a seal itself is just poppycock and I don't buy it. Fresh oil is still touching seals where an engine has sludge because that part is spinning/moving and opening galleyways for the oil to flow there.
Unless the seal is fully encapsulated in sludge I really do not see how a leak can be prevented. If that were the case parts would be grinding down into little metal pieces......though I have heard of sludge causing this in extreme cases.
If the car starts leaking after a change to synthetic it would have started leaking in any case. When a car has 140K miles plus things just go wrong.........
I'd better get my umbrella out now because I think its going to start raining insults :lol:
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Mike makes a lot of good points. Also, he used "poppycock" in a sentence, and is therefore the winner anyway. ;)
+1 to what Mike said. :D
- S
[Sold] '97 S70 T5
Has thanked: 1611 times
Been thanked: 4073 times
It is indeed an internet rule that the first to use ' poppycock' closes the thread.
Oil change threads on uncivilized boards are as bad as politics and religion.
I moved my fleet of 5 cars from Dino to full synthetic over the last couple years. No leaks, itches, or scratches.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
You accidentally did your car a favor. Stay with the full synthetic.
