'98 V70 GLT smoke from dipstick at 92k miles, clean pvc?
HydroHydra
Year and Model: '98 v70 GLT
Post by HydroHydra »
Hello and thanks for reading.
Like the title says, today while poking around under the hood I noticed white smoke coming from my dipstick. Not a lot I guess but enough to be noticeable. My car is at 92k miles, should I just replace or clean the PVC system like others recommend?
Also, how big of a problem is this?
Has thanked: 1609 times
Been thanked: 4064 times
A little smoke, not a biggie.
If it is puffing like a locomotive, you are better off leaving the stick out a bit and driving slowly and keeping revs down - high crankcase pressure will blow cam and crank seals and give you a big 1500 USD repair bill.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
HydroHydra wrote:...should I just replace or clean the PVC system like others recommend?
Yes, you'll need to replace the system. There's nothing to really clean besides the PTC near the Turbo.
obayha
Year and Model: V70 1999 Base
Post by obayha »
Have you done the glove test on the oil cap? Like said earlier, a little smoke could be OK. Any leaking around the cam seals? Has oil been changed at regular intervals? My car is at 172,000 with no PCV change yet and nothing is leaking. But it is said to have had the oil changed at every 3,000 miles.
As to the difficulty of doing the job. First time, on my '98, was a PITA and I did not do it perfect, which caused a few things to leak. Second time was much easier and I also cleaned the PTC near the turbo. That thing is fun to work with and it was pretty nasty.
Good write ups on here, just read them a few times before you start and it should work out good. The 12mm swivel head wrench is the best investment for this job.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
Smoke is OK even with clean PCV. (Assuming the glove test confirms the PCV has negative pressure).
Think about it, you unplug the dipstick, the system is "compromised" and is relieving pressure through that orifice. Kindof like creating a vacuum leak.
I have been working on the B230 engine recently, and boy do I miss the vacuum system on the white blocks.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
HydroHydra
Forgive my ignorance but what is the white glove test and determining the pressure? No cam seal leaks. The previous owner, the first one, took good care of the car in getting it serviced. Thank you.
bugs11
Year and Model: 850 1996
Post by bugs11 »
Latex/rubber glove test. Remove oil fill cap, place a latex/rubber glove over oil fill opening as if the oil fill opening is a hand with no fingers, start car, observe latex/rubber glove. If glove inflates PCV system is kaput, if glove tries to suck down in to oil fill opening PCV system is bueno.
I recently performed this test on my 1996 850, the glove blew off the oil fill opening, the dip stick looked like choo-choo train. The PCV hoses on the 850 are like rocks and will be replaced, if the head checks out - currently in the middle of head gasket replacement (blown).
bugs11
Post by bugs11 »
Watch the following YouTube video:
Glove test is around the 4:30 minute mark.
