1998 V70 Timing belt, cylinder head work 330k miles!
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Re: 1998 V70 Timing belt, cylinder head work 330k miles!
Post by 5rivers »
Greetings again!
Great news - I managed to install the plastic spacer on the tensioner!! I can't believe how tight the timing belt is!
And...the o-ring that I pictured with a few other washers (back a page or two) does indeed go to the breather (PCV) unit that attaches to the large hose connected to the throttle.
The plug/connector in the picture above that has an accordion type hose just below the connector attaches to the IAC valve. The other three-prong plug/connector is to the TPS sensor.
Still not sure where that black vacuum line attaches, but it is the one that goes under the airbox and into the firewall. I have the two vacuum lines that go to the airbox ready to attach once I install the throttle body gasket (due on Friday!).
Yet to install is the exhaust manifold and associated parts!
Appreciate all your help :D
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
Has thanked: 292 times
Been thanked: 765 times
5rivers wrote:... Still not sure where that black vacuum line attaches, but it is the one that goes under the airbox and into the firewall. ...
This sounds like the vacuum line to the cruise control pump, which is mounted under the battery tray.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
5rivers
Post by 5rivers »
I was just going to suggest that, and as a matter of fact, there is nipple under the battery tray without a vacuum line to it. I think we found the line a home!
Thanks, Erik!
5rivers
Has thanked: 1504 times
Been thanked: 3817 times
I'm betting 16 psi of boost we get a running video this weekend...or a still shot of the tach at 850 rpm
5rivers
Post by 5rivers »
I like your optimism!!
5rivers
5rivers
Post by 5rivers »
Ok, the throttle body mounting gasket is on! Now to attach breather parts, tube to airbox, IAC valve, add some coolant and oil, attach the exhaust manifold and the associated parts, re-attach battery lines AND double check everything before starting the car!
5rivers
The suspense is too much!
'06 S60 R, 197k
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Waiting to release the doves!
5rivers
Post by 5rivers »
Well, sorry about the delay in posting...I have had a bit of a setback...coolant is leaking at cylinder 4 from the head gasket, intake side. I am so totally bummed out. :( Any ideas on what would this suggest? Head bolts not tight enough, lower engine head in need of more sanding attention, a bad gasket? Appreciate your thoughts :)
Am now draining the engine of coolant.....
5rivers
songzunhuang
Year and Model: 98 V70 T5
Has thanked: 2 times
Been thanked: 30 times
Post by songzunhuang »
Aw that sucks. I feel your pain.
I've been watching this thread because I wanted to understand about the process of replacing a head gasket. It seems there are a lot of 1998-1999 cars for sale out there that have head gasket issues. I was wondering if I could get one inexpensively and replace. You are my proxy.
Best of luck. I'll keep rooting for you.
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
