1999 S70 NA PCV system fix caused misfire
kyalami321
- Year and Model: 1999 S70
Ok, finally fixed and it was the stupidest - yet cheapest - thing ever ... the coil wires were hooked to the wrong cylinders. Thank you all for your help regardless.
- Has thanked: 312 times
- Been thanked: 818 times
Awesome that you posted up the solution, thank you, it really helps. Trust me, you will by far not be the only one of us to make that miscue!
- Has thanked: 1613 times
- Been thanked: 4078 times
Way to go. Label them with some white tape so the next time this doesn't happen.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You allready had been pointed into that direction:kyalami321 wrote:Ok, finally fixed and it was the stupidest - yet cheapest - thing ever ... the coil wires were hooked to the wrong cylinders. Thank you all for your help regardless.
Sommerfeldt wrote:...Anyway - just to rule out the absolutely most basic thing that could cause your troubles... You're sure that you put coils and plug wires back in the right order...?
- S
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
kyalami321
Yup, I was. I didn't even consider that "order" meant specific wires tied to specific cylinders, but now I won't forget. Timing belt or suspension work will be my next projects. Thanks!misha wrote:You allready had been pointed into that direction:kyalami321 wrote:Ok, finally fixed and it was the stupidest - yet cheapest - thing ever ... the coil wires were hooked to the wrong cylinders. Thank you all for your help regardless.
- S
Remember an ME7 doesn't have cap rotor and wires - just plugs that attach to coil-on-plugs
I bet someone has tinkered with the wiring looms as on my 1999 you can't get the plugs into the wrong coils without really straining them.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
I kinda see what you mean, abscate, but if I remember correctly, it's possible to mess it up if you route the cables wrong between the coils. 3 & 4, for example.abscate wrote:Remember an ME7 doesn't have cap rotor and wires - just plugs that attach to coil-on-plugs
Anyway, it's good that the battery mishap didn't screw anything up, kyalami.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 172 Views
- 942 Views
- 20 Replies
- 3508 Views
Last post by scooterlovesvolvos3
- 12 Replies
- 6401 Views
Last post by erikv11
- 27 Replies
- 11912 Views
Last post by dono
