After dark, started up and drove a few blocks with everything normal. Parked to do a short errand, when I restarted the low beams didn't come on, and the turn signals don't work. I drove home holding the stalk for high beams.
Might that be a stalk failure or maybe (he hopes) a relay?
96 850 low beams went out + signals, stalk?
- Been thanked: 4064 times
Or possible ignition switch, electrical part. I would fault trace rather than throw parts.
Put a VOm in the car and a electrical diagram so you can trace it next time it happens
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Strange. I just tested it with key on and all was back to normal. I played with the key switch and it didn't seem flaky, but I wonder if I caught it just a hair off full contact last night to cause the outage.
OR might the relay be flaky? It worked right now, but after being on for a while, will it continue to?
I'm pretty sure I have another relay that I can test if it happens again.
I'll have time to test it further tomorrow.
- 13 Replies
- 4041 Views
Last post by Vova585
- 601 Views
Last post by cjrayburn1
- 10 Replies
- 1796 Views
Last post by Rattnalle
- 622 Views
Last post by mandkbean
- 2550 Views
Last post by IslandV70
