2002 s60 2.4T ac bearing size - confirmation required
Homebrand
Year and Model: 2002 s60 2.4T
Been thanked: 3 times
Post by Homebrand »
Hi All,
I have a noisy ac clutch pulley. It rattles at idle quite badly.
Thought I might have a go at replacing the bearing.
Does anyone know the bearing size/dimensions?
Edited and updated.
Can anyone confirm if the bearing size would be:
35mm ID x 55mm OD x 20mm Thick.
Cheers
Homebrand
Post by Homebrand »
Anyone?
Although looking at it closer I'll be damned if I know how I'll do it whilst it's still connected to the gas lines.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Are you sure it's not a belt tensioner or alternator? Those quit much faster.
Homebrand
Post by Homebrand »
Interesting you say that. I was almost certain it was the alternator.
I had a mechanic look at it and he said the a/c compressor.
I used a long handle screwdriver to listen to the alternator and the sound definetly came through clear as day when touching the alternator.
I'm going to triple check this.
I think you may be right.
I'll report back.
Cheers
Homebrand
Post by Homebrand »
Ok, reporting back. I didn't get around to replacing anything and the noise suddenly disappeared. That's either really good or really bad but either way it's gone.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
If you de-tension the belt you could check each pulley for play.
It looks like you have the correct dimensions for the clutch bearing:
http://www.autozone.com/cooling-heating ... _441026_0/
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
moussey
Year and Model: 2003 v70
Post by moussey »
Hello, I have a similar problem.
My 2003 V70 has developed a whine over about 6 months. Its definitely one of the items driven by the auxiliary belt since if I slacken it the whine stops the the engine is back to its former refined self.
I thought it was the tensioner, which had a little play, and having looked at this forum I changed that but no joy.
I just took off the auxilary belt again and the alternator spins freely and silently but the ac pulley sounds bad and has some wobble so I reckon its that.
So, to follow up the previous question, has anyone changed the bearing without taking off the compressor? Not sure if it has to be on the bench or if some sort of puller is needed to get the pulley/ bearing off.
Would love to hear from anyone who has changed the bearing on the bench and could say if they could have done in the car.
Thanks in advance
Has thanked: 1611 times
Been thanked: 4074 times
You can pop the clutch off the AC compressor but you have to,drop,the compressor down to access it. There is about 1 cm clearance between the clutch and the frame member installed.
moussey
Post by moussey »
Great, thanks, i will do as you say.
I just looked at the end of the pulley and can only see a small bolt in the centre. Any advice on how the pulley/ clutch is held on would be much appreciated.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The A/C clutch bearing doesn't whine, it makes a friction noise.
Maybe get a longer hose and with extreme care approach one end to the power steering pump (it will wine with the wrong fluid or if it sucks air) or other parts and listed at the ear at the other end. Again, watch your hands and rotating belt
www.youtube.com/watch?v=KAGDkwYSFY4
