Radio won't power on Topic is solved
frankI
I recently had the battery replaced in my 97 V90 wagon after it went completely dead. Now the radio doesn't power up at all ( so that I can't enter the anti-theft code etc.) I've checked the fuse and swapped it with others that work but no dice. Is there some other hidden fuse that need to check? Also not clear from the manual how to get to the back of the radio. This is an integrated CD, tape setup.
Hi FrankI, I would repost this in the Front Wheel Drive forum, you may find someone who has experienced the same trouble there.
I think that this should stay here by rear wheel drive Volvos, the V90 is actually the last Volvo 940 series, build just in 1998. ( Volvo thoght that V90 was a better name for the bigger 940 when they started to produce the V70). So if anyone has the same bad experience with the radio in a 940, please help FrankI
petershen1984
- Year and Model:
Ford Influence??LaRy wrote: ( Volvo thoght that V90 was a better name for the bigger 940 when they started to produce the V70).
Peter Shen
1992 Volvo 960 (Silver)
