Radio won't power on Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
frankI
Post by frankI »
I recently had the battery replaced in my 97 V90 wagon after it went completely dead. Now the radio doesn't power up at all ( so that I can't enter the anti-theft code etc.) I've checked the fuse and swapped it with others that work but no dice. Is there some other hidden fuse that need to check? Also not clear from the manual how to get to the back of the radio. This is an integrated CD, tape setup.
Volvord
Post by Volvord »
Hi FrankI, I would repost this in the Front Wheel Drive forum, you may find someone who has experienced the same trouble there.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
LaRy
Post by LaRy »
I think that this should stay here by rear wheel drive Volvos, the V90 is actually the last Volvo 940 series, build just in 1998. ( Volvo thoght that V90 was a better name for the bigger 940 when they started to produce the V70). So if anyone has the same bad experience with the radio in a 940, please help FrankI
petershen1984
Post by petershen1984 »
LaRy wrote: ( Volvo thoght that V90 was a better name for the bigger 940 when they started to produce the V70).
Ford Influence?? :-) ahem. I've read there's no significant difference between the last 960 and '98 V90, other than the model name..
Peter Shen
1992 Volvo 960 (Silver)
