98 v70r steering noises
Bren
Year and Model: 1998 V70R
Post by Bren »
Hey guys,
I'm hearing a plastic on plastic kind of noise when turning the steering wheel - Sounds like its coming from right near the base of the steering wheel itself, kinda as it goes into the dash.
I've searched but can't seem to find much other than people describing the problem..
is there a solution to this?
Garage:
1998 V70R
2006 XC90 2.5T - Family Hauler
1993 Audi S4 (Sold)
2001 VW Jetta 1.8T (Sold)
1988 Mazda 323 GTX (Sold in pieces)
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
The first step is probably for you to find out exactly where it's coming from - maybe you kicked or bumped something, something cracked and is rubbing, and so on. Sounds like a pretty car specific issue to me...
- S
[Sold] '97 S70 T5
Has thanked: 2199 times
Been thanked: 1852 times
Most likely is just the surround of the steering column rubbing on the steering column when turning. This may have come loose and just need the 3(?) torx screws either tightened or loosened and re-position the 2 halves of the column cover.
Another area to check is that there is nothing loose under the lower cover under the dashboard.
Finally, there is a bearing that can dry out at the bottom of the steering shaft where it goes through the floor. I recall someone doing a how-to on that.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
My '00 S70 did that. I noticed it when the weather got cooler.
I removed the 3 T25 torx screws from the bottom cover, and popped off the top cover. I found that the plastic was all cracked where the screws went into the plastic, and one of the clips on the top half was busted. There was almost nothing holding it in place.
I worked some plastic epoxy into the cracks, and stuck a paper reinforcement ring on each one. I also put a dab of that same epoxy where the clip on the top half was busted, essentially gluing them together, but not so much that I can't easily get them apart if need be.
I'm keeping my eye out for a set of gray ones (color code 3970) from the junkyard
Bren
Post by Bren »
I've tracked the noise down to the rubber boot where the steering column goes through the firewall...I've tried to spray some oil around it but the noise just comes back the next day...
any thoughts? this is very annoying...
Garage:
1998 V70R
1993 Audi S4 (Sold)
If you read my original note, I said there is a bearing there. The grease dries out over time and starts to squeak.
I recall reading a right up on how to access it and re-grease. I`ll try to find it when I get time, or try to search for it.
Bren
Post by Bren »
Nice thanks Neil!
I definitely don't have bearing in there and its definitely not on the steering shaft anywhere...
Is there a part number for this?
Garage:
1998 V70R
1993 Audi S4 (Sold)
Been thanked: 504 times
Post by cn90 »
Grease the white plastic collar where the SW column enters the firewall.
Bren
Post by Bren »
I don't have the collar!
Garage:
1998 V70R
1993 Audi S4 (Sold)
