04 XC90 ETM replacement
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
That's where they live. Need to remove turbo hoses and other components to access it. Don't know yet whether it's easier to access from top or bottom.
Current Volvos:
- FLXC90
ETM replacement on XC90 is same as on S60/V70 5 cylinder. I looked at one today. In your case, follow the hose from the lower LH side of the intercooler, to the intake. There it is. To replace, remove the intake hose, The wire bundle goes behind the starter, may be easier to remove starter to get wires out, then it 's just bolts. Check the ETM room forum for a tutorial, or You tube.
Current Volvos:
- FLXC90
It figures that they require programming. I thought the Bosch ETBs were good to go.
Current Volvos:
- 3529 Views
Last post by ajwsurfer
- 3949 Views
Last post by antonevane
